[Qgis-developer] QGIS hangs when trying to add stops in color ramp
Giovanni Manghi giovanni.manghi at gmail.com
Mon May 24 12:59:45 EDT 2010
can you please open a ticket (if not already) in the qgis bug tracker.
The same for the other problem you reported (create new spatialite layer
fails).
Cheers
-- Giovanni --
On Sun, 2010-05-23 at 15:50 -0500, Cline, Royce L. wrote:
> Using the Style Manager, I an trying to create a stop in a gradient color ramp. With Multiple stops selected, i click the Add stop button and the color dialog appears where I then select the color and click OK. The Offset of the stop dialog appears. Whether I click Cancel or OK, QGIS no longer responds when the dialog closes. At this point I must kill QGIS.
> Tested with QGIS dev builds r13385 and r13519 from KyngChaos using OS X 10.6.3.
> Royce_______________________________________________
> Qgis-developer mailing list
