[Qgis-developer] osm plugin problem
Luca Delucchi lucadeluge at gmail.com
Tue May 25 11:45:34 EDT 2010
2010/5/24 Paolo Cavallini <cavallini at faunalia.it>:
> On Sun, 23 May 2010 21:33:09 +0200, Luca Delucchi <lucadeluge at gmail.com>
> wrote:
>> Hi everybody I use osm plugin a bit deeper and i found a problem with
>> the editing, i cannot add a new node or a new line; i can only add a
>> node on old data and create a line over old data, someone try it and
>> found also this problem?
> You mean this?
> https://trac.osgeo.org/qgis/ticket/1944
no, i cannot create new elements. I can only add some new node in the old line
> All the best.
cheers
Luca
