[Qgis-developer] osm plugin problem
Martin Dobias wonder.sk at gmail.com
Fri May 28 10:22:15 EDT 2010
Hi Luca
On Tue, May 25, 2010 at 5:45 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> 2010/5/24 Paolo Cavallini <cavallini at faunalia.it>:
>> On Sun, 23 May 2010 21:33:09 +0200, Luca Delucchi <lucadeluge at gmail.com>
>> wrote:
>>> Hi everybody I use osm plugin a bit deeper and i found a problem with
>>> the editing, i cannot add a new node or a new line; i can only add a
>>> node on old data and create a line over old data, someone try it and
>>> found also this problem?
>> You mean this?
>> https://trac.osgeo.org/qgis/ticket/1944
> no, i cannot create new elements. I can only add some new node in the old line
Please create a ticket for the problem and attach as many details as
possible - what happens if you try to add new elements, platform etc.
Martin
