[Qgis-developer] GoogleLayers
Giovanni Manghi
giovanni.manghi at gmail.com
Tue May 25 17:34:00 EDT 2010
Hi Ivan,
the attached file made the trick, no more crashes under ubuntu when
opening the project file.
I tested the plugin under windows on other machines and I always see the
same behaviour: or the already reported pyhton error or it adds only
tiles with z:0.
thanks!
-- Giovanni --
On Tue, 2010-05-25 at 22:15 +0200, Ivan Mincik wrote:
> > Under Linux (ubuntu) things seems to work better, but if I save a
> > project that includes one or more tiles, then when I try to reopen the
> > project qgis crashes with the following message
> > Error:
> > GDAL Error 6: No translation an empty SRS to PROJ.4 format is known.
> > Segmentation fault
> I have found the reason of this problem. Would You please try to
> replace original 'GoogleLayers.py' file with file attached in this
> mail and test on Ubuntu?
> Ivan
