[Qgis-developer] GoogleLayers
Ivan Mincik
ivan.mincik at gista.sk
Wed May 26 03:17:37 EDT 2010
On Tuesday 25 May 2010, Giovanni Manghi wrote:
> Hi Ivan,
> the attached file made the trick, no more crashes under ubuntu when
> opening the project file.
> I tested the plugin under windows on other machines and I always see the
> same behaviour: or the already reported pyhton error or it adds only
> tiles with z:0.
OK. This patch was just for problem on Linux (GDAL Error 6: No translation an empty SRS to PROJ.4 format is known.).
Thanks for testing.
Ivan Mincik
