[Qgis-developer] GoogleLayers
Giovanni Manghi giovanni.manghi at gmail.com
Thu May 27 10:12:10 EDT 2010
Hi Ivan
> > I tested the plugin under windows on other machines and I always see the
> > same behaviour: or the already reported pyhton error or it adds only
> > tiles with z:0.
> OK. This patch was just for problem on Linux (GDAL Error 6: No translation an empty SRS to PROJ.4 format is known.).
> Thanks for testing.
I just seen a very similar problem on a Linux machine, Ubuntu 10.04,
qgis trunk.
the plugins just add tiles with z:0 or throws
An error has occured while executing Python code:
  File "/home/ubc/.qgis/python/plugins/GoogleLayers/GoogleLayers.py",
line 151, in run
    # write image file + world file to disk
ValueError: math domain error
cheers
-- Giovanni --
