[Qgis-developer] Re: problems with shapes projections,
now also under linux
Giovanni Manghi
giovanni.manghi at gmail.com
Fri May 28 19:31:46 EDT 2010
more notes.
I tested r13584 under ubuntu 10.04: in general it recognize shapes crs
that are in qgis db, but fails with shapes crs that are not in db. This
message is shown in the context ba
crs undefined - defaulting to default CRS
the same that appens under windows as described in ticket #2601
There are other shapes that r13584 fails to read right crs, like
http://www.igeo.pt/produtos/cadastro/caop/download/CAOP20090_Shapes/Cont_AAd_CAOP20090.zip
http://www2.apambiente.pt/atlas/dl/regista_dl.jsp?zona=continente&grupo=&tema=c_redehidro
with the same two shapes I don't have problems with r13569 under ubuntu
9.04
Under windows .qpj files are written in c:\ with xp, and are not written
at all under Seven, probably because it does not allow to write in c:\
cheers
-- Giovanni --
On Fri, 2010-05-28 at 17:15 +0100, Giovanni Manghi wrote:
> Hi all,
> I am using qgis trunk r13502 under ubuntu linux (10.04) and I'm seeing
> problems with shapes projections:
> When opening a shape qgis do not show the right crs in the "properties
> -> general" menu, regardless if the vector projection is available in
> the qgis crs list or not (in my case it shows wgs84 as defined in
> "options -> CRS").
> This is similar to
> https://trac.osgeo.org/qgis/ticket/2601
> as seen on windows, that by the way seems to me a show stopper on the
> road to 1.5
> Moreover when saving a shape ("save as...") the .qpj file is saved in
> the home folder instead of the choosen location.
> Cheers
> -- Giovanni --
