[Qgis-developer] problems with shapes projections, now also under linux
Giovanni Manghi giovanni.manghi at gmail.com
Fri May 28 12:15:51 EDT 2010
Hi all,
I am using qgis trunk r13502 under ubuntu linux (10.04) and I'm seeing
problems with shapes projections:
When opening a shape qgis do not show the right crs in the "properties ->
general" menu, regardless if the vector projection is available in the qgis
crs list or not (in my case it shows wgs84 as defined in "options -> CRS").
This is similar to
https://trac.osgeo.org/qgis/ticket/2601
as seen on windows, that by the way seems to me a show stopper on the road
to 1.5
Moreover when saving a shape ("save as...")  the .qpj file is saved in the
home folder instead of the choosen location.
Cheers
-- Giovanni --
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100528/98603c57/attachment.html
