[Qgis-developer] Re: [GRASS-dev] current state of r.li
Hamish
hamish_b at yahoo.com
Fri Nov 12 16:35:08 EST 2010
Paolo wrote:
> As some of you know, the r.li suite of GRASS
> commands allows landscape analyses[0]. Its
> interface is rather complex, and is still in
> TclTk, not ported to either wxpython or qgis. As
> such, it is now more difficult to use than it
> should be, and it will become unusable when TclTk
> support will be dropped.
> The possible solution (thanks Radim) is to rewrite
> the interface as a qgis python plugin. It should
> not be a huge work
I just looked at r.li.setup's .tcl files. it is some
work but as you say not a huge amount to port it to
another GUI frontend. (circa one dozen functions,
~1000 lines of code)
there is no reason to only do qgis or wxPython, we
should do both!
http://trac.osgeo.org/grass/browser/grass/trunk/raster/r.li/r.li.setup
the bigger issue for r.li was r.li.daemon et al
using UNIXisms which didn't work on MS Windows..
but IIRC Glynn already fixed that in grass7?
Hamish
