[Qgis-developer] upgrading to spatialite 2.4.0-RC4
a.furieri at lqt.it
a.furieri at lqt.it
Thu Nov 25 06:55:04 EST 2010
Hi All,
I've just finished merging the latest
SpatiaLite 2.4.0-RC4 in QGIS-trunk:
a) I've updated the 'internal' spatialite
sources: -/src/core/spatialite/*
b) the most interesting new feature now
supported in spatialite is the so called
"DB self-initialization": this practically
means that each time a new DB is created
from scratch, then the spatial metadata
tables [GEOMETRY_COLUMNS and
SPATIAL_REF_SYS] will be automatically
created. And the whole EPSG dataset will
be silently loaded into SPATIAL_REF_SYS.
So there is no longer any need to copy
a template DB as in previous versions,
because now a brand new DB can be created
simply calling the appropriate APIs
c) accordingly to this, I've modified
-/src/app/qgsnewspatialitelayerdialog.*
in order to support "DB self-initialization"
d) I've applied the same change on
-/src/plugins/offline_editing/offline_editing.*
where I found another function strictly
corresponding to c)
e) after all this I've then removed any
definition of: qgisSpatialiteDbTemplatePath()
because this seems to be obsolete and no
longer required:
-/src/core/qgsapplication.*
-/python/core/qgsapplication.sip
question #1: do you foresee any possible
issue deriving from the above changes ?
[I've performed some testing and anything
seem to work as expected, but any further
advice is obviously welcome]
question #2: may I commit the above changes ?
or do you think it would be better waiting
until after the 1.6.0 final release ?
bye Sandro
