[Qgis-developer] Re: [Qgis-user] qgis 1.6 crashes
Giovanni Manghi
giovanni.manghi at gmail.com
Mon Nov 29 12:29:32 EST 2010
try remove the SDA4PP plugin, it gave problems with rasters in the past.
Cheers
-- Giovanni --
On Mon, Nov 29, 2010 at 5:08 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
> Hi!
> Not sure how to get the list of pluggins. What I do is sending you the
> output sent to the console, I assume that the offending plugging must
> be one those that appear as "loaded". Tell me if there is a better way.
> It's certainly a problem with a plugging, as I've just found the same
> problem on a third machine running qgis 1.6 (ubuntu 10.04),
> I've also started to uninstall pluggings, no luck yet. Just know that
> qgis --noplugins works fine:
> alobo at HPepito:~$ qgis
> Python support ENABLED :-)
> Loaded : Geoprocessing (package: geoprocessing)
> Loaded : Numerical Vertex Edit (package: numericalVertexEdit)
> Loaded : Image Boundary (package: imgboundary)
> Loaded : Table Manager (package: tablemanager)
> Loaded : RasterCalc (package: rastercalc)
> Loaded : GdalTools (package: GdalTools)
> Loaded : Rectangles (package: rectangles)
> Loaded : Quickly save default qml (package: quicksaveqml)
> Loaded : Profile (package: profiletool)
> Loaded : Raster File Info Plugin (package: rasterinfo)
> /usr/lib/python2.6/dist-packages/osgeo/gdal.py:80: DeprecationWarning:
> gdal.py was placed in a namespace, it is now available as osgeo.gdal
> DeprecationWarning)
> Loaded : DEM relief shader (package: shadedrelief)
> Loaded : Mirror Map Plugin (package: mirrormap)
> Loaded : Zip Layers (package: ziplayers)
> Loaded : Zoom to Point - Modified-bb (package: zoom_to_point_BB)
> Loaded : Raw raster file import (package: rawrasterfileimport)
> Loaded : Closest Feature Finder (package: ClosestFeatureFinder)
> Loaded : SelectPlus Menu (package: selectplus)
> Loaded : 1-Band Raster Colour Table (package: bcccoltbl)
> Loaded : CadTools (package: cadtools)
> SUB marker line 1
> Loaded : Symbology-NG (package: symbology_ng)
> Loaded : Click-fu (package: clickfu)
> Loaded : SRTM elevation importer for Qgis (package: qgissrtm)
> Loaded : Reference Map Plugin (package: refmap)
> Loaded : Rasterlang (package: rasterlang)
> Loaded : PostGIS SQL Query Editor (package: postgisquery)
> Loaded : Spectral Profile (package: spectral_profile)
> NEW LOGGING | 29.11.2010 18:07:02 | SDA4PP, Version=0.195
> CLASS NAME | FUNCTION NAME | VARIABLE NAME = VALUE
> sda4pp | initGui | pyqt version= 4.6.2
> LoadRlib | checkPartners | Checking rpy2.
> rpy2 version= 2.0.8
> LoadRlib | checkPartners | Checking R-cran.
> LoadRlib | checkPartners | Plug-in will run, rpy2 and R are called.
> Geospatial Data Abstraction Library extensions to R successfully loaded
> Loaded GDAL runtime: GDAL 1.7.3, released 2010/11/10
> Path to GDAL shared files: /usr/share/gdal17
> Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009
> Path to PROJ.4 shared files: (autodetected)
> LoadRlib | loadRgdal | rgdal package loaded.
> sda4pp | initGui | rgdal package is loaded.
> Note: polygon geometry computations in maptools
> depend on the package gpclib, which has a
> restricted licence. It is disabled by default;
> to enable gpclib, type gpclibPermit()
> Checking rgeos availability as gpclib substitute:
> FALSE
> LoadRlib | loadMaptools | maptools package loaded.
> sda4pp | initGui | maptools package is loaded.
> This is mgcv 1.7-2. For overview type 'help("mgcv-package")'.
> deldir 0.0-10
> Please note: The process for determining duplicated points
> has changed from that used in version 0.0-9.
> spatstat 1.17-2 (Type ‘help(spatstat)’ for information)
> LoadRlib | loadSpatstat | spatstat package loaded.
> sda4pp | initGui | spatstat package is loaded.
> wl | manageConfFile | mode = "writeInit"
> wl | manageConfFile | index = ""
> wl | manageConfFile | tool = ""
> Loaded : Spatial Data Analysis for Point Pattern (package: SDA4PP)
> Loaded : Google Layers (package: GoogleLayers)
> Loaded : Plugin Installer (package: plugin_installer)
> Loaded : Geocoding (package: GeoCoding)
> Loaded : MultiQml (package: multiqml)
> Loaded : RGB Composition Plugin (package: rgb)
> Loaded : ShowHideImg (package: imgshowhide)
> Loaded : 1-Band Raster Colour Table V1.x (package: bcccoltbl1)
> Loaded : MapSheetAutoGeoRef (package: MapSheetAutoGeoRef)
> Loaded : Image Clipper (package: image_clipper)
> Loaded : manageR (package: manageR)
> Loaded : Copypasta (package: copypasta)
> Loaded : Scattergram (package: scattergram)
> Loaded : TopoColour (package: topocolour)
> Loaded : Point sampling tool (package: pointsamplingtool)
> Loaded : OpenLayers Plugin (package: openlayers)
> Loaded : Interactive Identify (package: infotool)
> Loaded : Statist (package: statist)
> Loaded : Colour Scale Bar (package: bccscbar)
> Loaded : Value Tool (package: valuetool)
> Loaded : DumpLoadField (package: dumpfield)
> Loaded : fTools (package: fTools)
> Loaded : MapServer Export (package: mapserver_export)
> Error:
> GDAL Error 4: `/media/FREECOM_HDD/VGT/SM/untitled folder/subs.bil'
> does not exist in the file system,
> and is not recognised as a supported dataset name.
> Segmentation fault
> 2010/11/29 Giuseppe Sucameli <sucameli at faunalia.it>:
>> Hi Agustin,
>> On Mon, Nov 29, 2010 at 1:36 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
>>> I think it is the gdal tools, as this is what I get on the console
>>> after the crash:
>>> Loaded : OpenStreetMap plugin (package: osm)
>>> Error:
>>> Error: use of NULL environment is defunct
>>> During startup - There were 16 warnings (use warnings() to see them)
>>> *** stack smashing detected ***: /usr/bin/qgis.bin terminated
>>> Segmentation fault
>> I'm pretty sure that the crash is not due to GdalTools.
>> In fact GdalTools doesn't load anything since the user clicks on one of the
>> tools in
>> the Raster menu, instead seems that a plugin tries to load a .bil file from
>> an invalid
>> (maybe hard-coded) path...
>> The "GDAL Error" message is printed by the libgdal, not the GdalTools plugin
>> at all.
>> BTW, can you send us a list containing the installed plugins?
>> Cheers.
>>> gdaltools are not there when I start with qgis --noplugins
>>> but cannot uninstall it if I start normally, as it comes now bundled,
>>> so I cannot fully test.
>>> Agus
>>> 2010/11/29 Agustin Lobo <alobolistas at gmail.com>:
>>> > Has to be that, as the crash does not occur if I start qgis with
>>> > qgis --noplugins
>>> > I'll ty to identify the offending plugin, any ideas?
>>> > Agus
>>> > 2010/11/29 Jürgen E. <jef at norbit.de>:
>>> >> Hi Agus,
>>> >> On Mon, 29. Nov 2010 at 12:12:50 +0100, Agustin Lobo wrote:
>>> >>> No crash for vector layers, crash for raster layers.
>>> >>> The test consists of:
>>> >>> 1. Open qgis and load a raster layer
>>> >>> 2. Save the project and close qgis
>>> >>> 3. move or rename the raster layer
>>> >>> 4. Open qgis and open the saved project
>>> >>> 5. Crash
>>> >> Do have anything "unusual" installed? Like custom build GDAL and/or
>>> >> plugins
>>> >> other might not have?
>>> >> Jürgen
>>> >> Jürgen E. Fischer norBIT GmbH Tel.
>>> >> +49-4931-918175-20
>>> >> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>>> >> +49-4931-918175-50
>>> >> Software Engineer D-26506 Norden
>>> >> http://www.norbit.de
>>> >> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme
>>> >> mbH
>>> >> Rheinstrasse 13, 26506 Norden
>>> >> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>>> >> _______________________________________________
>>> >> Qgis-user mailing list
>>> >> Qgis-user at lists.osgeo.org
>>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Giuseppe Sucameli
> Qgis-developer mailing list
