[Qgis-developer] Re: [Qgis-user] qgis 1.6 crashes
Giovanni Manghi
giovanni.manghi at gmail.com
Mon Nov 29 16:09:20 EST 2010
On Mon, 2010-11-29 at 17:29 +0000, Giovanni Manghi wrote:
> Hi,
> try remove the SDA4PP plugin, it gave problems with rasters in the past.
I have the SDA4PP plugin installed and I experience no crashes, but the
plugin is not really activated as it doesn't recognize that I have
installed the necessary R packages with synaptic (from cran2deb) and I
cannot compile them either. So I cannot really confirm or not if is this
plugin the cause of the problems.
cheers
-- Giovanni --
> On Mon, Nov 29, 2010 at 5:08 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
> > Hi!
> > Not sure how to get the list of pluggins. What I do is sending you the
> > output sent to the console, I assume that the offending plugging must
> > be one those that appear as "loaded". Tell me if there is a better way.
> > It's certainly a problem with a plugging, as I've just found the same
> > problem on a third machine running qgis 1.6 (ubuntu 10.04),
> > I've also started to uninstall pluggings, no luck yet. Just know that
> > qgis --noplugins works fine:
> > alobo at HPepito:~$ qgis
> > Python support ENABLED :-)
> > Loaded : Geoprocessing (package: geoprocessing)
> > Loaded : Numerical Vertex Edit (package: numericalVertexEdit)
> > Loaded : Image Boundary (package: imgboundary)
> > Loaded : Table Manager (package: tablemanager)
> > Loaded : RasterCalc (package: rastercalc)
> > Loaded : GdalTools (package: GdalTools)
> > Loaded : Rectangles (package: rectangles)
> > Loaded : Quickly save default qml (package: quicksaveqml)
> > Loaded : Profile (package: profiletool)
