[Qgis-developer] Qgis 1.5 and Grass 6.4 can't open NVIZ under mac
os x
William Kyngesburye
woklist at kyngchaos.com
Tue Oct 12 18:28:46 EDT 2010
Normally when GRASS is run, it sets up an environment which includes a setting* to locate library binaries within the GRASS folder structure, just in case they are expected somewhere else, like NVIZ is looking for that ffmpeg library. When I package GRASS, I try to fix these, though that setting will catch what I miss.
Qgis should take care of this as well, but maybe it isn't. Or should I read that literally, and you are trying to run NVIZ directly from a terminal, without running GRASS first?
Looking at NVIZ, I see that it may also have problems with TclTk later - either not finding the bundled copy, or finding the system one, which is older and may cause trouble...
* On *nix systems it's LD_LIBRARY_PATH, but on OS X it's DYLD_LIBRARY_PATH.
On Oct 12, 2010, at 4:30 PM, Luca Mandolesi wrote:
> Hi,
> I'm working under mac os x 10.5.8 with qgis 1.5 and grass 6.4.
> If I try to launch NVIZ appear this message:
> /Applications/GRASS-6.4.app/Contents/MacOS/bin/nviz --interface-description
> dyld: Library not loaded: /Users/Shared/unix/ffmpeg-leo/lib/libavutil.dylib Referenced from: /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_ogsf.dylib Reason: image not found
> Suggestions?
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
