[Qgis-developer] Plugin Offline editing: first tests
Mathias Walker mwa at sourcepole.ch
Thu Oct 14 05:42:01 EDT 2010
Hi Paolo
Am Donnerstag, 14. Oktober 2010, um 10.18:43 schrieb Paolo Cavallini:
> Il 10/10/2010 10:11, Paolo Cavallini ha scritto:
> > I'm testing the plugin and found some issues. While converting to
> > offline, I get a warning (from the shell) and an error (with a popup):
> > WARNING:  there is no transaction in progress
> > ERROR: 313 feature(s) not added
> > Could not commit changes to layer comuni (offline)
> > but the layer seems to be copied. So I edit it, and I get another error
> > while committing the changes to the SL db:
> > Errors: ERROR: 314 feature(s) not added.
> > I tested this with 2 different polygon layers, with the same problem.
> > Points are handled well.
> Hi all.
> Anyone confirms this? If I have some hints, I can do further tests.
> All the best, and thanks.
What source database are you using? Are there any special settings or missing
primary keys in the polygon layers?
Best regards
Mathias Walker
Sourcepole -  Linux & Open Source Solutions
Elestastr. 18   7310 Bad Ragaz  Switzerland
Tel: 081 330 77 11       Fax: 081 330 77 12
mwa at sourcepole.ch  http://www.sourcepole.ch
