[Qgis-developer] Plugin Offline editing: first tests
Paolo Cavallini
cavallini at faunalia.it
Thu Oct 14 04:18:43 EDT 2010
Il 10/10/2010 10:11, Paolo Cavallini ha scritto:
> I'm testing the plugin and found some issues. While converting to offline, I get a
> warning (from the shell) and an error (with a popup):
> WARNING: there is no transaction in progress
> ERROR: 313 feature(s) not added
> Could not commit changes to layer comuni (offline)
> but the layer seems to be copied. So I edit it, and I get another error while
> committing the changes to the SL db:
> Errors: ERROR: 314 feature(s) not added.
> I tested this with 2 different polygon layers, with the same problem. Points are
> handled well.
Hi all.
Anyone confirms this? If I have some hints, I can do further tests.
All the best, and thanks.
Paolo Cavallini: http://www.faunalia.it/pc
