[Qgis-developer] qgis-mapserver docs
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Wed Sep 1 01:58:57 EDT 2010
Hi Paolo
You don't need the admin.sld if you work with the project file as a
configuration. 'admin.sld' is still supported for backwards compatibility (also
because it uses the same code as parsing SLD sent by clients).
The publish to web plugin in this form is not necessary any more. In future,
it would however be usefull to turn it into a graphical editor for the
mapserver related properties in the project files.
Regards,
Marco
Am Sonntag, 29. August 2010, um 16.25:01 schrieb Paolo Cavallini:
> Il 29/08/2010 16:02, Paolo Cavallini ha scritto:
> > - in my installation (debs compiled from trunk), I cannot find the
> > Publish to Web plugin: should this be fixed?
> Apparently the plugin is no longer used: so is the admin.sld file still
> useful? If so, how should it be edited?
> All the best.
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Webereistrasse 66, 8134 Adliswil, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
