[Qgis-developer] qgis-mapserver docs
Paolo Cavallini
cavallini at faunalia.it
Wed Sep 1 02:14:51 EDT 2010
Il 01/09/2010 07:58, Marco Hugentobler ha scritto:
> You don't need the admin.sld if you work with the project file as a
> configuration. 'admin.sld' is still supported for backwards compatibility (also
> because it uses the same code as parsing SLD sent by clients).
> The publish to web plugin in this form is not necessary any more. In future,
> it would however be usefull to turn it into a graphical editor for the
> mapserver related properties in the project files.
Hi Marco.
Thanks a lot for clarifying this.
Any plans to incorporate an updated documentation into the main QGIS manual?
Overall, I must say it's a pleasure to set up and use the server.
BTW: any plans to extend it to WFS as well, so we could replace the good old (UMN)
Mapserver?
All the best, and again many thanks.
Paolo Cavallini: http://www.faunalia.it/pc
