[Qgis-developer] qgis-mapserver docs
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Wed Sep 1 03:25:00 EDT 2010
Hi Paolo
> Any plans to incorporate an updated documentation into the main QGIS
> manual?
Yes, it would be very helpful to integrate the updated docs into the manual.
Unfortunately, at the moment, I don't have time to work on the docs, so any
help in this respect would be greatly appreciated.
> BTW: any plans to extend it to WFS as well, so we could replace the good
> old (UMN) Mapserver?
Not from my side. But it would be possible e.g. by creating a class
QgsWFSServer (similarly to the QgsWMSServer class that is used for the WMS
requests).
Btw., TinyOWS is also quite good as a light-weight WFS server with support for
WFS-T.
Regards,
Marco
Am Mittwoch, 1. September 2010, um 08.14:51 schrieb Paolo Cavallini:
> Il 01/09/2010 07:58, Marco Hugentobler ha scritto:
> > You don't need the admin.sld if you work with the project file as a
> > configuration. 'admin.sld' is still supported for backwards compatibility
> > (also because it uses the same code as parsing SLD sent by clients).
> > The publish to web plugin in this form is not necessary any more. In
> > future, it would however be usefull to turn it into a graphical editor
> > for the mapserver related properties in the project files.
> Hi Marco.
> Thanks a lot for clarifying this.
> manual? Overall, I must say it's a pleasure to set up and use the server.
> All the best, and again many thanks.
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Webereistrasse 66, 8134 Adliswil, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
