AW: [Qgis-developer] Not Rendering the Shapefile in Canvas - Blank
Möri Cedric
Cedric.Moeri at bd.so.ch
Fri Sep 10 08:18:09 EDT 2010
Hi Noli
seems you're missing self.canvas.refresh() at the end of your code.
regards
Cédric
mit freundlichen Grüssen
Cédric Möri
GIS-Informatiker
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon: +41 (0)32 627 24 75
Telefax: +41 (0)32 627 22 14
mailto:cedric.moeri at bd.so.ch
http://www.agi.so.ch
----- Originalnachricht -----
Von: "Noli Sicad" <nsicad at gmail.com>
Gesendet: Fre, 10.9.2010 14:03
An: qgis-developer <qgis-developer at lists.osgeo.org>
Betreff: [Qgis-developer] Not Rendering the Shapefile in Canvas - Blank
Is there any reason why the shapefile is not rendering in this code
(below)? I tried several shapefiles and yet I am getting a white
canvas or blank canvas without a render. I was able to open the
shapefile and the form with mapcanvas are showing. Yet no render of
the polygons - totally blank.
self.canvas.setCanvasColor(Qt.white) <---- a White Canvas without
render - BLANK
Thanks. Noli
class ShapeViewer(QMainWindow, Ui_MainWindow):
def __init__(self):
QMainWindow.__init__(self)
# Required by Qt4 to initialize the UI
self.setupUi(self)
# Set the title for the app
self.setWindowTitle("ShapeViewer")
# Create the map canvas
self.canvas = QgsMapCanvas()
self.canvas.useImageToRender(False)
self.canvas.show()
# Lay our widgets out in the main window using a
# vertical box layout
self.layout = QVBoxLayout(self.frame)
self.layout.addWidget(self.canvas)
# layout is set - open a layer
# Add an OGR layer to the map
file = QFileDialog.getOpenFileName(self,
"Open Shapefile", ".", "Shapefiles (*.shp)")
fileInfo = QFileInfo(file)
# Add the layer
layer = QgsVectorLayer(file, fileInfo.fileName(), "ogr")
if not layer.isValid():
return
# Add layer to the registry
QgsMapLayerRegistry.instance().addMapLayer(layer);
# Set extent to the extent of our layer
self.canvas.setExtent(layer.extent())
# Set up the map canvas layer set
cl = QgsMapCanvasLayer(layer)
layers = [cl]
self.canvas.setLayerSet(layers)
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
