[Qgis-developer] Not Rendering the Shapefile in Canvas - Blank
Noli Sicad nsicad at gmail.com
Fri Sep 10 08:34:11 EDT 2010
Hi  Cédric
I inserted self.canvas.refresh() as showed below but still a blank canvas.
 # Set up the map canvas layer set
    cl = QgsMapCanvasLayer(layer)
    layers = [cl]
    self.canvas.setLayerSet(layers)
Thanks.
Noli
On 9/10/10, Möri Cedric <Cedric.Moeri at bd.so.ch> wrote:
> Hi Noli
> seems you're missing self.canvas.refresh() at the end of your code.
> regards
> Cédric
> mit freundlichen Grüssen
> Cédric Möri
> GIS-Informatiker
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> Rötistrasse 4
> 4501 Solothurn
> Telefon: +41 (0)32 627 24 75
> Telefax: +41 (0)32 627 22 14
> mailto:cedric.moeri at bd.so.ch
> http://www.agi.so.ch
> ----- Originalnachricht -----
> Von: "Noli Sicad" <nsicad at gmail.com>
> Gesendet: Fre, 10.9.2010 14:03
> An: qgis-developer <qgis-developer at lists.osgeo.org>
> Betreff: [Qgis-developer] Not Rendering the Shapefile in Canvas - Blank
> Hi,
> Is there any reason why the shapefile is not rendering in this code
> (below)? I tried several shapefiles and yet I am getting a white
> canvas or blank canvas without a render. I was able to open the
> shapefile and the form with mapcanvas are showing. Yet no render of
> the polygons - totally blank.
> self.canvas.setCanvasColor(Qt.white)  <---- a White Canvas without
> render - BLANK
> Thanks. Noli
> class ShapeViewer(QMainWindow, Ui_MainWindow):
>   def __init__(self):
>     QMainWindow.__init__(self)
>     # Required by Qt4 to initialize the UI
>     self.setupUi(self)
>     # Set the title for the app
>     self.setWindowTitle("ShapeViewer")
>     # Create the map canvas
>     self.canvas = QgsMapCanvas()
>     self.canvas.useImageToRender(False)
>     self.canvas.show()
>     # Lay our widgets out in the main window using a
>     # vertical box layout
>     self.layout = QVBoxLayout(self.frame)
>     self.layout.addWidget(self.canvas)
>     # layout is set - open a layer
>     # Add an OGR layer to the map
>     file = QFileDialog.getOpenFileName(self,
>                    "Open Shapefile", ".", "Shapefiles (*.shp)")
>     fileInfo = QFileInfo(file)
>     # Add the layer
>     layer = QgsVectorLayer(file, fileInfo.fileName(), "ogr")
>     if not layer.isValid():
>       return
>      # Add layer to the registry
>     QgsMapLayerRegistry.instance().addMapLayer(layer);
>     # Set extent to the extent of our layer
>     self.canvas.setExtent(layer.extent())
>     layers = [cl]
> Qgis-developer mailing list
