[Qgis-developer] Python dynamic forms
Bernhard Ströbl Bernhard.Stroebl at jena.de
Thu Sep 16 02:24:47 EDT 2010
Hi Jeremy,
I had a similar problem recently when I wanted to share the same
connection amongst several plugins. What I did is to create a "master"
plugin which adds a menu in the menu bar when initialized. I created a
psycopg.connection - Object and attached it to the menu. Each plugin
using this connection creates an instance of the master-plugin class. If
the master-plugin class has been initialized by another plugin (menu
added, connection set up) the master-plugin object is initialized
differently: the existing connection is used.
I am not sure if this is the way one should do this but it works :)
Be sure to end the transaction after each sql-command issued
(con.commit() or con.rollback()) even after a SELECT, see:
http://initd.org/psycopg/docs/faq.html
How do you access the widgets in the custom ui in your ui-init function?
Here is the code:
class MasterPlugin():
     def __init__( self, iface ):
         self.iface = iface
         self.menu = None
         self.title = "&Master Plugin"
         self.con = None # ini
         menu_bar = self.iface.mainWindow().menuBar()
         actions = menu_bar.actions()
         # has the menu been added by another plugin?
         for action in actions:
             if action.text() == self.title:
                 self.menu = action.menu()
                 self.actMenu = action
                 self.con = self.menu.con
                 break
         if self.menu == None:
             # create the menu
             self.menu = QMenu()
             self.menu.setTitle( self.title )
             lastAction = actions[ len( actions ) - 1 ]
             self.actMenu = menu_bar.insertMenu( lastAction, self.menu )
	    #some stuff left out here
	    con = self.dbConnect( selected )
             if con:
                self.con = con
                self.menu.con = con
class OtherPlugin():
     def initGui(self):
         # create MasterPlugin object
         self.mp = MasterPlugin( self.iface )
     def selectFromDB( self ):
	cur = self.mp.con.cursor()
hope this helps
Bernhard
Jeremy Palmer schrieb:
> Hi All!
> I’m trying to use custom forms for adding and editing features within a
> layers.
> The forms that I’m creating need to query a PostgreSQL database to
> populate controls. Using the UI init function seems like the thing to do
> here. I’ve managed to populate the controls by setting up a new
> connection and executing the query from within this init function.
> However these forms will be opened up all the time, and from a database
> administrators point of view I would like cache the database connection
> so a new connection is not created every time the form is opened. To
> make things more complicated I would like to share this connection
> across multiple feature forms within one QGIS user project. I also have
> a few other functions relating to the admin of these layers that I
> currently have in a plug-in which also needs the same database connection.
> Is there a way to do connection caching with all of this? I thought
> about having a singleton class in my plug-in that stores this
> connection, but it looks like I can’t access the plug-in registry from
> the PyQGIS api L
> Note I’m using psycopg2 for the database connections.
> Thanks,
> Jeremy
> This message contains information, which is confidential and may be
> subject to legal privilege.
> If you are not the intended recipient, you must not peruse, use,
> disseminate, distribute or copy this message.
> If you have received this message in error, please notify us immediately
> (Phone 0800 665 463 or info at linz.govt.nz <mailto:info at linz.govt.nz> )
> and destroy the original message.
> LINZ accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ.
> *Thank you.*
> *________ Information from NOD32 ________*
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
> Qgis-developer mailing list
Dipl.-Geogr. Bernhard Ströbl
Anwendungsbetreuer GIS
Kommunale Immobilien Jena
  - Datenverarbeitung -
mailto:Bernhard.Stroebl at jena.de
http://kij.jena.de/
