[Qgis-developer] Python dynamic forms
Jeremy Palmer
JPalmer at linz.govt.nz
Thu Sep 16 03:48:00 EDT 2010
Oh ok I haven't try the QPSQL driver. So does the QT framework have rich support for using PostgreSQL?
I'm also gathering that the QT driver fits in better with the QT model control paradigm?
Thanks,
Jeremy
-----Original Message-----
From: luca_manganelli at comune.trento.it [mailto:luca_manganelli at comune.trento.it]
Sent: Thursday, September 16, 2010 7:15 PM
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Python dynamic forms
Bernhard Ströbl <Bernhard.Stroebl at jena.de> scritti il 16/09/2010 08.41.12
> Hi Luca,
> what is the advantage? (I am curious)
> regards
> Bernhard
Because it's integrated into QT framework.
Again, in my QGIS 1.5 Windows install if I do this at Python Console:
>>> import psycopg2
File "<input>", line 1, in <module>
File "U:/Applicazioni/qgis-1.5.0-2/apps/qgis/./python\qgis\utils.py", line
291, in _import
ImportError: No module named psycopg2
so...
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
