[Qgis-developer] Re: cmake error on OS X 10.6
Matthew Denno
mgdenno at gmail.com
Thu Sep 16 20:52:40 EDT 2010
John and William,
Thank you for your input.
So both of you have used the procedure presented in the Install Guide? I
guess I will uninstall the MacPorts libs, etc and try the methods from the
guide again.
Could one of you please tell me the name of the Qt pakage you used? It
looks like there are a number to choose from, SDK, debug, etc. I think this
might have been where I went wrong before.
Thanks again for your help.
Matt
On Sep 16, 2010 11:03 AM, "John C. Tull" <john.tull at wildnevada.org> wrote:
As far as I can tell, I do not have any remnant gsl laying around. I
upgraded my hardware in the past 6 months and started afresh with additional
unix libs, binaries, etc. I did not install any gsl other than your
framework to my knowledge.
I believe some updates occurred in the past 6-10 months with egis where your
frameworks are automagically picked up by cmake. Here is my commandline
output from running the cmake command I posted:
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Checking whether C compiler has -isysroot
-- Checking whether C compiler has -isysroot - no
-- Checking whether C compiler supports OSX deployment target flag
-- Checking whether C compiler supports OSX deployment target flag - no
-- Check for working C compiler: /usr/local/bin/ccache
-- Check for working C compiler: /usr/local/bin/ccache -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Checking whether CXX compiler has -isysroot
-- Checking whether CXX compiler has -isysroot - no
-- Checking whether CXX compiler supports OSX deployment target flag
-- Checking whether CXX compiler supports OSX deployment target flag - no
-- Check for working CXX compiler: /usr/local/bin/ccache
-- Check for working CXX compiler: /usr/local/bin/ccache -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Quantum GIS version: 1.6.0 Trunk (10600)
-- Found GRASS: /Applications/GRASS-6.4.app/Contents/MacOS (6.4.0)
-- Found Iconv: /usr/lib/libiconv.dylib
-- Looking for openpty
-- Looking for openpty - found
-- Found Proj: /Library/Frameworks/proj.framework
-- Found Expat: /usr/lib/libexpat.dylib
-- Using GSL from /Library/Frameworks/GSL.framework/Versions/1/unix
-- Found GEOS:
/Library/Frameworks/GEOS.framework/Versions/3/unix/lib/libgeos_c.dylib
-- Found GDAL:
/Library/Frameworks/GDAL.framework/Versions/1.7/unix/lib/libgdal.dylib
-- Found PostgreSQL: /usr/local/pgsql/lib/libpq.dylib
-- Found QWT: /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - not found.
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found.
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found.
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - found
-- Looking for QT_MAC_USE_COCOA
-- Looking for QT_MAC_USE_COCOA - found
-- Found Qt-Version 4.7.0 (using /usr/bin/qmake)
-- Found PythonInterp:
/System/Library/Frameworks/Python.framework/Versions/2.6/bin/python2.6
-- Found Python executable:
-- Found Python version: 2.6.1
-- Found Python library: -framework Python
-- Found SIP version: 4.10.5
-- Found PyQt4 version: 4.7.4
-- Found FCGI: /usr/lib/libfcgi.dylib
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/jctull/sources/qgis/trunk/build
You can see that gsl, proj and others were discovered just fine.
Cheers,
John
On Sep 16, 2010, at 7:57 AM, William Kyngesburye wrote:
> Interesting. You don't have problems w...
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100916/a66fd17d/attachment.html
