[Qgis-developer] Re: cmake error on OS X 10.6
William Kyngesburye
woklist at kyngchaos.com
Fri Sep 17 09:55:03 EDT 2010
On Sep 16, 2010, at 7:52 PM, Matthew Denno wrote:
> John and William,
> Thank you for your input.
> So both of you have used the procedure presented in the Install Guide? I guess I will uninstall the MacPorts libs, etc and try the methods from the guide again.
> Could one of you please tell me the name of the Qt pakage you used? It looks like there are a number to choose from, SDK, debug, etc. I think this might have been where I went wrong before.
It's hard to get the wrong one. Either the SDK or the library-only package works (though the SDK has a few 100 MB of extra stuff you don't need), and the debug libs (unnecessary) won't install without the libraries or SDK installed.
Note: do you want to try latest new features/bug fixes in trunk, or just use Qgis as released? I have the binaries on my site. I haven't done a dev build in a while, so maybe I should do that this weekend...
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
