[Qgis-developer] Re: cmake error on OS X 10.6
Matthew Denno
mgdenno at gmail.com
Fri Sep 17 14:47:16 EDT 2010
Using python configure.py takes care of the architecture (I.e. 32 vs 64 bit)
too?
On Sep 17, 2010 1:56 PM, "William Kyngesburye" <woklist at kyngchaos.com>
wrote:
With the python.org python, you just use the first form:
python configure.py
That defaults to putting everything in the python framework.
That said, I haven't tried it in a long time, since I don't use the
python.org python. You may get deployment target complaints from python.
On Sep 17, 2010, at 12:22 PM, Matthew Denno wrote:
> Forgot to reply all.
> ---------- Forwarde...
> Qgis-developer mailing list
> Qgis-developer at lis...
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you
ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000
times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100917/d7dd753c/attachment-0001.html
