[Qgis-developer] Re: cmake error on OS X 10.6
William Kyngesburye woklist at kyngchaos.com
Fri Sep 17 13:56:08 EDT 2010
With the python.org python, you just use the first form:
python configure.py
That defaults to putting everything in the python framework.
That said, I haven't tried it in a long time, since I don't use the python.org python.  You may get deployment target complaints from python.
On Sep 17, 2010, at 12:22 PM, Matthew Denno wrote:
> Forgot to reply all.
> ---------- Forwarded message ----------
> From: Matthew Denno <mgdenno at gmail.com>
> Date: Fri, Sep 17, 2010 at 1:15 PM
> Subject: Re: [Qgis-developer] Re: cmake error on OS X 10.6
> To: William Kyngesburye <kyngchaos at kyngchaos.com>
> On Fri, Sep 17, 2010 at 12:15 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> On Sep 17, 2010, at 10:44 AM, Matthew Denno wrote:
> > Last night I downloaded the 64bit Qt library-only package (The SDK didn't say if it was 32 or 64 bit).  I went through the Installation Guide again and this time was able to get past the SIP/PyQt installs following the guide.  The only thing I had to do that wasn't in the guide was add the non-framework path to PYTHONPATH in my .bash-profile.
> > PYTHONPATH='/Library/Python/2.6/site-packages'
> > export PYTHONPATH
> Even that should not be necessary.  That path is wired into the system python.  If you installed and use the python.org python, it's not set there, but then you should compile python extensions into it's site-packages.
> Oh.  Okay.  I have the python.org version installed. so my SIP/PyQt configure should have "-d /Library/Frameworks/Python.framework/Versions/2.6/python2.6/site-packages" not "-d /Library/Python/2.6/site-packages"
> I am still figuring out the whole OS X directory structure and though that that was the system python...not realizing that there is a python at /System/Library/...  As a result I have SIP/PyQt split into two places.  None in the System Python but in both other locations mentioned above.
> I guess I have some clean-up to do.
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed robot?
[Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
