[Qgis-developer] Re: cmake error on OS X 10.6
John C. Tull john.tull at wildnevada.org
Fri Sep 17 17:41:20 EDT 2010
Matthew,
Is there a specific reason to use python.org? Generally speaking, it seems to prove best on OS X to avoid overriding system provided bins and libs when possible.
Cheers,
John
On Sep 17, 2010, at 1:39 PM, William Kyngesburye wrote:
> I think it will default to 32bit.
> On Sep 17, 2010, at 1:47 PM, Matthew Denno wrote:
>> Using python configure.py takes care of the architecture (I.e. 32 vs 64 bit) too?
>>> On Sep 17, 2010 1:56 PM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
>>> With the python.org python, you just use the first form:
>>> python configure.py
>>> That defaults to putting everything in the python framework.
>>> That said, I haven't tried it in a long time, since I don't use the python.org python.  You may get deployment target complaints from python.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
> Qgis-developer mailing list
