[Qgis-developer] Re: cmake error on OS X 10.6
Matthew Denno
mgdenno at gmail.com
Fri Sep 17 22:04:06 EDT 2010
Update: I removed all old SIP/PyQt installs (I think I got them all) as
well as the python.org version of python. Reinstalled everything from the
Installation Guide, but alas I am still getting the same error. I think I
may have found the solution though, it looks like it may be a known bug
https://trac.osgeo.org/qgis/ticket/2985. There is a diff included that
might fix it. Is applying a diff difficult? (ha). I will poke around the
internet and see if I can find out how to do it. Any direction would be
appreciated.
On Fri, Sep 17, 2010 at 6:33 PM, Matthew Denno <mgdenno at gmail.com> wrote:
> Thank so much to both of you for your input. You both know much more about
> this than I do so I shall follow your lead.
> I discovered that there is some guidance in the python documentation
> regarding uninstalling...and it agrees with Williams advice so I will do it.
> On Fri, Sep 17, 2010 at 6:25 PM, John C. Tull <john.tull at wildnevada.org>wrote:
>> William knows much more about all of this than I do. With that said, I am
>> a significant portion of the testing on OS X, and I have never used
>> python.org. I would say dump it if you don't explicitly need it. Also,
>> work out getting a build system for qgis that works, then start to tinker if
>> you have to do so.
>> Cheers,
>> John
>> On Sep 17, 2010, at 4:16 PM, William Kyngesburye wrote:
>> > There are 2 camps on this: system and python.org, though I don't want
>> to start a debate about that here ;) Both are valid, though I prefer the
>> system version, and it's also the one most tested with Qgis as far as I
>> know.
>> > If you want to uninstall python.org, deleting
>> /Library/Frameworks/Python.framework is a start. It probably also has added
>> something to your PATH in your ~/.bash_profile. And there also may be
>> symlinks and scripts in /usr/local/bin, and maybe some headers or symlinks
>> in /usr/local/include.
>> > On Sep 17, 2010, at 4:49 PM, Matthew Denno wrote:
>> >> John, I guess the only reason was that I wanted to use Idle at one
>> time. I don't care anymore though. In your opinion would it be better
>> uninstall the python.org version? Will that remove
>> \Library\Frameworks\Python.frameworks...?
>> >> I am just trying to figure out how to proceed to get this cleaned up
>> and working.
>> >>> On Sep 17, 2010 5:41 PM, "John C. Tull" <john.tull at wildnevada.org>
>> wrote:
>> >>> Matthew,
>> >>> Is there a specific reason to use python.org? Generally speaking, it
>> seems to prove best on OS X to avoid overriding system provided bins and
>> libs when possible.
>> >>> Cheers,
>> >>> John
>> >>> On Sep 17, 2010, at 1:39 PM, William Kyngesburye wrote:
>> >>>> I think it will default to 32bit.
>> >>>> O...
>> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> > http://www.kyngchaos.com/
>> > "This is a question about the past, is it? ... How can I tell that the
>> past isn't a fiction designed to account for the discrepancy between my
>> immediate physical sensations and my state of mind?"
>> > - The Ruler of the Universe
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100917/70248d97/attachment.html
