[Qgis-developer] Re: cmake error on OS X 10.6
Matthew Denno
mgdenno at gmail.com
Fri Sep 17 23:04:27 EDT 2010
Well, if I am understanding this correctly, it looks like this diff has
already been applied to trunk. However, it seems like this is where the
problem might be.
On Fri, Sep 17, 2010 at 10:04 PM, Matthew Denno <mgdenno at gmail.com> wrote:
> Update: I removed all old SIP/PyQt installs (I think I got them all) as
> well as the python.org version of python. Reinstalled everything from the
> Installation Guide, but alas I am still getting the same error. I think I
> may have found the solution though, it looks like it may be a known bug
> https://trac.osgeo.org/qgis/ticket/2985. There is a diff included that
> might fix it. Is applying a diff difficult? (ha). I will poke around the
> internet and see if I can find out how to do it. Any direction would be
> appreciated.
> On Fri, Sep 17, 2010 at 6:33 PM, Matthew Denno <mgdenno at gmail.com> wrote:
>> Thank so much to both of you for your input. You both know much more
>> about this than I do so I shall follow your lead.
>> I discovered that there is some guidance in the python documentation
>> regarding uninstalling...and it agrees with Williams advice so I will do it.
>> On Fri, Sep 17, 2010 at 6:25 PM, John C. Tull <john.tull at wildnevada.org>wrote:
>>> William knows much more about all of this than I do. With that said, I am
>>> a significant portion of the testing on OS X, and I have never used
>>> python.org. I would say dump it if you don't explicitly need it. Also,
>>> work out getting a build system for qgis that works, then start to tinker if
>>> you have to do so.
>>> Cheers,
>>> John
>>> On Sep 17, 2010, at 4:16 PM, William Kyngesburye wrote:
>>> > There are 2 camps on this: system and python.org, though I don't want
>>> to start a debate about that here ;) Both are valid, though I prefer the
>>> system version, and it's also the one most tested with Qgis as far as I
>>> know.
>>> > If you want to uninstall python.org, deleting
>>> /Library/Frameworks/Python.framework is a start. It probably also has added
>>> something to your PATH in your ~/.bash_profile. And there also may be
>>> symlinks and scripts in /usr/local/bin, and maybe some headers or symlinks
>>> in /usr/local/include.
>>> > On Sep 17, 2010, at 4:49 PM, Matthew Denno wrote:
>>> >> John, I guess the only reason was that I wanted to use Idle at one
>>> time. I don't care anymore though. In your opinion would it be better
>>> uninstall the python.org version? Will that remove
>>> \Library\Frameworks\Python.frameworks...?
>>> >> I am just trying to figure out how to proceed to get this cleaned up
>>> and working.
>>> >>> On Sep 17, 2010 5:41 PM, "John C. Tull" <john.tull at wildnevada.org>
>>> wrote:
>>> >>> Matthew,
>>> >>> Is there a specific reason to use python.org? Generally speaking, it
>>> seems to prove best on OS X to avoid overriding system provided bins and
>>> libs when possible.
>>> >>> Cheers,
>>> >>> John
>>> >>> On Sep 17, 2010, at 1:39 PM, William Kyngesburye wrote:
>>> >>>> I think it will default to 32bit.
>>> >>>> O...
>>> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> > http://www.kyngchaos.com/
>>> > "This is a question about the past, is it? ... How can I tell that the
>>> past isn't a fiction designed to account for the discrepancy between my
>>> immediate physical sensations and my state of mind?"
>>> > - The Ruler of the Universe
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100917/fa54f678/attachment.html
