[Qgis-developer] QGis AutoGCP Plugin
Carson Farmer
carson.farmer at gmail.com
Wed Sep 29 13:29:50 EDT 2010
I think this is probably what you're looking for:
crs = QgsCoordinateReferenceSystem ()
crs.createFromProj4(theProj4Str)
print crs.toWkt()
no need to use additional libraries or anything!
On 29 September 2010 17:18, Benoit de Cabissole <benoit at exigesa.com> wrote:
> Hi Francois,
> If you are in Python, you could use GDAL with something like the following:
> import osr
> theProj4Str = "+proj=utm +zone=36 +south +a=6378249.144808011
> +b=6356514.966204134 +units=m +no_defs"
> outSr = osr.SpatialReference()
> outSr.ImportFromProj4(theProj4Str)
> outWkt = outSr.ExportToWkt()
> and use outWkt as the 'dst_wtk' parameter for raster creation.
> HTH,
> Benoit
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org
> [mailto:qgis-developer-bounces at lists.osgeo.org]On Behalf Of Francois Maass
> Sent: Wednesday, 29 September 2010 17:33
> To: qgis-developer at lists.osgeo.org
> Subject: [Qgis-developer] QGis AutoGCP Plugin
> Hello everyone!
> I’ve been struggling with this for quite some time now, but I can’t seem to
> find the proper solution. We need to set the projection definition to
> provided datasets, and have, up to now, been doing it by using our own
> projection dialog. We now want to change our plugin to use the, already
> implemented, QGIS projection dialog.
> So my question is as follows:
> Is there a way to convert a projection definition such as those returned by
> the QGIS projection dialog
> eg:
> +proj=utm +zone=36 +south +a=6378249.144808011 +b=6356514.966204134
> +units=m +no_defs
> to the extended form such as the following:
> PROJCS["UTM Zone 36, Southern Hemisphere",GEOGCS["Unknown datum based
> upon the Clarke 1880 ellipsoid",DATUM["Not specified (based on Clarke 1880
> spheroid)",SPHEROID["Clarke
> 1880",6378249.144808011,293.4663076556303,AUTHORITY["EPSG","7034"]]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",33],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",10000000],UNIT["Meter",1]]
> The reason for this is that the GDAL functions for setting the projection
> definition, only accepts the extended form. If this is already implemented
> in a QGIS or other class that you know of, I would greatly appreciate it.
> (I don’t think I am qualified enough to attempt doing it myself. J )
> Thank you for your time and efforts!
> Francois Maass
> Foxhat Solutions
> Qgis-developer mailing list
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation
National University of Ireland, Maynooth,
http://www.carsonfarmer.com/
