[Qgis-developer] GRASS vectors unusable on win
Giovanni Manghi
giovanni.manghi at gmail.com
Wed Apr 6 05:41:28 EDT 2011
Just as reminder. The problems are described here
https://trac.osgeo.org/qgis/ticket/3648
https://trac.osgeo.org/qgis/ticket/3650
https://trac.osgeo.org/qgis/ticket/3646
On Tue, 2011-04-05 at 14:06 +0100, Giovanni Manghi wrote:
> The problems are described in three tickets I linked here in the past days.
> g.remove does not work on wingrass then it does not work also in qgis.
> About the other two it seems that was about problems with the dbf
> support. A comment seems to point that these problem have been already
> solved in the latest grass versions (I don't if there were backports
> in grass 6.4).
> cheers
> -- Giovanni --
> On Tue, Apr 5, 2011 at 2:01 PM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> > Hi all.
> > IMHO, the GRASS vector support is currently unusable on windows.
> > Importing and removing vectors does not work reliably. I think we should
> > either fix it or drop the plugin on windows before the release.
> > All the best.
> > Paolo Cavallini: http://www.faunalia.it/pc
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
