[Qgis-developer] GSoC proposal: DBManager
    Giuseppe Sucameli
    sucameli at faunalia.it
    Tue Apr  5 11:32:25 EDT 2011
Hi devs,
I'd like to attend the GSoC 2011 as student to develop the following idea:
http://www.qgis.org/wiki/Google_Summer_of_Code_2011#Database_Manager
Brief.
I think PG_manager is a very useful plugin because permits users to get
informations
and run queries on a PG database from within QGis. Furthermore PG_manager
GUI is
very intuitive!
So, at the HF in Pisa (2010.04) I starting to develop SL_manager, based on
PG_manager but working on SpatiaLite databases. Unfortunately I didn't
adapted the
existent code to manage SL databases, instead I forked it.
Now there're 2 different plugins based on the same code and it's very
difficult
maintaining both as porting fixes between them and adding new features could
require a lot of time.
There's another plugin based on PG_manager, it's the RT_Sql_Layer plugin
which
allow users to load a PG or SL layer using whatever select statement.
Proposal.
My aim is to merge both 3 plugins together and create the DB_manager plugin.
First and the most important requirement, the DB_manager plugin *must* be
easily
expandable to manage different kind of databases (e.g. mysql, ...).
I didn't look ahead when I forked PG_manager, but I want to correct my
mistakes.
Second, it should permit an easy management of databases, running common
tasks
as create/alter/delete tables, retrieve infos about tables, run queries, ...
Those are implemented in PG/SL_manager yet, but I have to do some changes to
make them more general than they are.
Third, DB_manager should allow to load tables as layer on the QGis canvas
and,
on the contrary, import layers from the canvas into the db.
What is your opinion? Did I miss something?
What other features would you like to see? And what other plugins (if any)
would it be
good to integrate in?
Thanks for your comments.
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110405/b571be80/attachment.html
