[Qgis-developer] creatensis.pl problem
David Silva Barrera dsilva at uci.cu
Sun Apr 17 10:09:11 EDT 2011
Thanks Fischer, in fat it was the problem. I removed this parts of the script and packed manually all DLLs and qgis preinstalled binaries.
Finally runned the last part of creatensis.pl script and successed.
Thanks again.
David
----- Mensaje original -----
De: "Jürgen E. Fischer" <jef at norbit.de>
Para: qgis-developer at lists.osgeo.org
Enviados: Sábado, 16 de Abril 2011 4:50:59 (GMT-0500) Auto-Detected
Asunto: Re: [Qgis-developer] creatensis.pl problem
Hi David,
On Thu, 14. Apr 2011 at 15:17:14 -0400, David Silva Barrera wrote:
> I'm trying to make a qgis package. Following INSTALL instructions I went
> to Ubuntu, installed nsis and executed creatensis.pl in it's own folder
> ../ms-windows/osgeo4w/. It freezes, after a will (long one); I press
> Control + C three times, the last one make it show this result:
Looks like your wget hangs. You probably killed the first three downloads.
Try running
wget http://qgis.org/downloads/System.dll
wget http://nsis.sourceforge.net/mediawiki/images/9/9d/Untgz.zip
wget http://www.nirsoft.net/utils/nircmd.zip
manually. That should give you some insight.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110417/4e8f1b05/attachment.html
