[Qgis-developer] creatensis.pl problem
Jürgen E. Fischer jef at norbit.de
Sat Apr 16 04:50:59 EDT 2011
Hi David,
On Thu, 14. Apr 2011 at 15:17:14 -0400, David Silva Barrera wrote:
>    I'm trying to make a qgis package. Following INSTALL instructions I went
>    to Ubuntu, installed nsis and executed creatensis.pl  in  it's  own folder
>    ../ms-windows/osgeo4w/. It freezes, after a will (long one); I press
>    Control + C three times, the last one make it show this result:
Looks like your wget hangs.  You probably killed the first three downloads.
Try running
wget http://qgis.org/downloads/System.dll
wget http://nsis.sourceforge.net/mediawiki/images/9/9d/Untgz.zip
wget http://www.nirsoft.net/utils/nircmd.zip
manually.  That should give you some insight.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
