[Qgis-developer] How often is qgis srs.db synced with gdal srs database
Hilmy Hashim hilmyh at gmail.com
Sat Apr 23 05:19:55 EDT 2011
As I understand it, qgis srs.db is populated from the gdal srs database. I
am using qgis 1.7-dev at now revision 15786 on OSGeo4W.
The RSO projections I'm using: EPSG:3168 and EPSG:3375 does not have
complete proj4 parameters - missing +gamma. The latest gdal using epsg_tr.py
has the correct set.
>From ticket #3645, it looks like a patch was submitted some 6 weeks ago to
sync srs.db with the latest gdal, but I'm not seeing it. Will I be seeing an
updated srs.db only on 1.7 final release?
Thanks
*Hilmy*
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110423/d7dbb961/attachment.html
