[Qgis-developer] White stripes when panning map
Ivan Mincik
ivan.mincik at gmail.com
Sat Apr 23 16:21:48 EDT 2011
I see this behavior on three different machines with different graphic cards.
> Do the white stripes disappear when panning is finished?
Yes, it will disappear when panning is finished.
> I don't have this effect on my machines here, but it could be related to the
> resize crash fix (http://trac.osgeo.org/qgis/changeset/15771). Could you check
> if the white stripes go away if you remove the few lines in qgsmapcanvas.cpp?
Yes, it started when installed daily build containing that changeset.
I can test removing lines later, if needed.
Ivan
