[Qgis-developer] problem with QGIS 1.7 "--snapshot"?
Tim Sutton
lists at linfiniti.com
Wed Aug 3 04:48:13 EDT 2011
Hi Jim
I'm guessing this is something to do with the new on the fly
reprojection support for rasters (the main difference between 1.6 and
1.7). I was able to replicate the issue here on the release-1_7_0
branch with all backported fixes applied. Under master branch, it
didnt even get as far as producing a snapshot. Could you file a ticket
for this? We will try to fix it for 1.7.1 9assign the ticket to me for
now).
Thanks
Tim
On Tue, Aug 2, 2011 at 5:13 PM, Jim Hammack <hammack at gotslack.org> wrote:
> I have a simple project which includes a BlueMarble geotiff background, a
> shapefile of U.S. state boundaries, and several shapefiles of projected
> tropical storm tracks. When I save an image of the map interactively using
> the "Save as Image" menu item, the resulting png file accurately reflects
> what is on the screen. However, when I save an image from the command line
> using "$ qgis tropical.qgs --snapshot snapshot.png" the BlueMarble image is
> shifted. You can see the images here (I converted the png files to jpeg to
> save space/bandwidth):
> http://gotslack.org/hammack/qgis
> I am running QGIS 1.7 built from scratch on a Slackware 13.1 system. All of
> the files are in epsg:4326. I have the same problem if I use a TrueMarble
> geotiff in place of the BlueMarble so it seems like a problem with
> "snapshot" rather than with the data. I used the same method last hurricane
> season with QGIS 1.6 and had no problems.
> Any ideas?
> Thanks,
> Jim
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
