[Qgis-developer] Reorganizing GdalTools
Alexander Bruy
alexander.bruy at gmail.com
Tue Aug 9 11:11:51 EDT 2011
Hi Paolo,
2011/8/9 Paolo Cavallini <cavallini at faunalia.it>:
> A few questions questions:
> * I'm not completely sure Contour should go under Extraction; it does not fit well
> anywhere, but I think it is closer to Conversion than anything else. In this case,
> the Clipper should go under Miscellaneous.
Yes, I also not sure about this, so I commit it as is after discussion
with Giuseppe
> * Also, the order within submenus is probably best set on the basis of similarity; in
> this case, I would place Near black closer to Sieve.
Well, I'll move Near black closer to Sieve.
> * Moreover, now it could be the right time to add a menu also for
> http://www.gdal.org/gdal_fillnodata.html and
> http://svn.osgeo.org/gdal/trunk/gdal/swig/python/scripts/gdal_calc.py
+1. If I found time, I can try to implement this
Alexander Bruy
