[Qgis-developer] profile plugins
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Fri Aug 12 06:36:43 EDT 2011
Hi Paolo
> I've also noticed the recent Export profile plugin: does it take only 2
> points, as per the notice, or there are more, as it appears from the
> exported file? Also, I have inspected the xml result, and tags are in
> German. Finally, how best use the xml to display elevation?
> Thanks.
If you mean the profile plugin in the sourcepole repo: it does not do
visualisation, only xml export. The xml format is the one of a cablecar
planning software, that's why the tags are in german.
However, it could be extended to write to other formats as well.
As input, the plugin needs a selected line (normally a two-point profile line).
The number of points in the ouput file is determined by the given sampling
distance and elevation tolerance.
Regards,
Marco
Am Freitag, 12. August 2011, 12.23:46 schrieb Paolo Cavallini:
> Hi all.
> In Debian unstable, qwt5 -py has been dropped, and AFAICT perspectives we
> have to move to qwt6 (no py available yet). As a consequence, the profile
> tool plugin (possibly others?) is no longer working. Any plan to fix this?
> Thanks.
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
