[Qgis-developer] profile plugins
Paolo Cavallini cavallini at faunalia.it
Fri Aug 12 09:58:42 EDT 2011
Il 12/08/2011 12:36, Marco Hugentobler ha scritto:
> If you mean the profile plugin in the sourcepole repo: it does not do
> visualisation, only xml export. The xml format is the one of a cablecar
> planning software, that's why the tags are in german.
> However, it could be extended to write to other formats as well.
> As input, the plugin needs a selected line (normally a two-point profile line).
> The number of points in the ouput file is determined by the given sampling
> distance and elevation tolerance.
ok, thanks for clarifying.
all the best.
Paolo Cavallini: http://www.faunalia.it/pc
