[Qgis-developer] Raster transparency: spinbox does not work
Alister Hood
alister.hood at synergine.com
Wed Aug 17 01:42:51 EDT 2011
Sorry, I don't know. Like a lot of plugins, I can't see any relevant
trackers for it, so I guess you need to contact the developers directly.
> -----Original Message-----
> From: Paolo Cavallini [mailto:cavallini at faunalia.it]
> Sent: Wednesday, 17 August 2011 5:27 p.m.
> To: Alister Hood
> Cc: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Raster transparency: spinbox does not
work
> Il 17/08/2011 00:37, Alister Hood ha scritto:
> > Just to be clear: you are talking about the RasterTransparency
plugin
> > from the GIS-Lab Repository, aren't you?
> Exactly.
> > I imagine you are right: with QGIS trunk on Windows there is only an
> > error message if you try to use the slider, but using the spinbox
> > doesn't seem to do anything (there is no error message).
> So, where should I open a ticket then?
> All the best.
> Paolo Cavallini: http://www.faunalia.it/pc
