[Qgis-developer] Raster transparency: spinbox does not work
Paolo Cavallini cavallini at faunalia.it
Wed Aug 17 01:27:21 EDT 2011
Il 17/08/2011 00:37, Alister Hood ha scritto:
> Just to be clear: you are talking about the RasterTransparency plugin
> from the GIS-Lab Repository, aren't you?
Exactly.
> I imagine you are right: with QGIS trunk on Windows there is only an
> error message if you try to use the slider, but using the spinbox
> doesn't seem to do anything (there is no error message).
So, where should I open a ticket then?
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
