[Qgis-developer] Raster transparency: spinbox does not work
Alister Hood
alister.hood at synergine.com
Tue Aug 16 18:37:01 EDT 2011
Hi Paolo,
Just to be clear: you are talking about the RasterTransparency plugin
from the GIS-Lab Repository, aren't you?
I imagine you are right: with QGIS trunk on Windows there is only an
error message if you try to use the slider, but using the spinbox
doesn't seem to do anything (there is no error message).
Alister
> Date: Tue, 16 Aug 2011 16:48:36 +0200
> From: Paolo Cavallini <cavallini at faunalia.it>
> Subject: [Qgis-developer] Raster transparency: spinbox does not work
> To: qgis-developer <qgis-developer at lists.osgeo.org>
> Message-ID: <4E4A8344.8090603 at faunalia.it>
> Content-Type: text/plain; charset=UTF-8
> Hi all.
> Selecting the min-max level for raster transparency works well with
the slider;
> it
> does not if increasing or decreasing the values using the spin boxes
or typing
> in the
> text area.
> Anyone confirms? Should I open a ticket?
> All the best.
> Paolo Cavallini: http://www.faunalia.it/pc
