[Qgis-developer] analytical workflow
Noli Sicad nsicad at gmail.com
Tue Aug 23 09:12:57 EDT 2011
There is PyQt Visual Modeller for R package (i.e. Red R) which is sort
of derivative of Orange.
Red R
http://www.red-r.org/
Orange
http://orange.biolab.si/features.html
This is similar to ArcGIS Model Builder.
The beauty of Red-R and Orange is uses python and Qt (i.e. PyQt), so I
can be easily adapted for QGIS instead of using WxPython which Grass
use.
Noli
On 8/23/11, Werner Macho <werner.macho at gmail.com> wrote:
> Hi!
> I agree with martin - such a Modeler could be a great improvement but
> I assumed it would be somethink like the WxGUI_Modeler ..
> (Also ESRI has something like that)
> Putting things(modules) together like a diagram would be much easier
> for the user than remembering a chain ..
> Did not Tim start something like that with Openmodeler?
> (http://openmodeller.sourceforge.net/)
> Do you think we could use that?
> regards
> Werner
> On Tue, Aug 23, 2011 at 2:08 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
>> Hi Paolo
>> On Mon, Aug 22, 2011 at 10:51 AM, Paolo Cavallini <cavallini at faunalia.it>
>> wrote:
>>> Hi all.
>>> One of the great thing we plan to develop for the new Processing
>>> framework it to make
>>> easy for user to pipe one command into another, so to build complex
>>> workflows of
>>> analysis.
>>> One idea: add a + button on the single module window to add further
>>> modules in a
>>> chain, taking the output of the first command and giving it as an input
>>> to the next
>>> one; moreover we could have a Save button to store the command sequence
>>> in a file.
>>> Of course one could think of more complex extensions, adding support for
>>> cycles,
>>> recursivity etc., but this seems a simple approach to start with.
>>> Comments or ideas?
>> I am not sure if it makes sense to spend time on a solution like this
>> because the number of use cases is quite limited. Surely one could
>> create simple linear chains of modules, but creating anything more
>> complex would be quite inconvenient (e.g. a process where module C
>> uses output of modules A and B). I believe that a graphical model
>> builder (where a box = module, an arrow = data transfer) is the only
>> long term solution, something like this:
>> http://grass.osgeo.org/wiki/WxGUI_Modeler
>> Martin
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
