[Qgis-developer] GDAL Raster Merge
Alexander Bruy
alexander.bruy at gmail.com
Fri Aug 26 10:59:35 EDT 2011
Hi
2011/8/26 uk52rob <uk52rob at yahoo.co.uk>:
> 1. The file size of the merged GeoTiff is over 10x the size of the
> combined originals;
Try to enable compression adding creation options to your command.
More info you can find in GeoTiff format page [0]
> 2. The merged map is in greyscale only, and needs to be in colour.
By default GDAL merge all input rasters into single band image. May be you
problem can be solved by adding "-separate" parameter.
[0] http://www.gdal.org/frmt_gtiff.html
Alexander Bruy
