[Qgis-developer] new plugin scenario
Tim Sutton
lists at linfiniti.com
Fri Aug 26 17:59:11 EDT 2011
Hi
On Thu, Aug 25, 2011 at 2:03 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi Richard
> On Mon, Aug 22, 2011 at 9:00 PM, Richard Duivenvoorde
> <rdmailings at duif.net> wrote:
>> I want it to be a 'proper' qgis plugin, so please correct me if I'm wrong:
>> - I upload my code to github
>> (what's the idea there: to put it in github in my own space:
>> https://github.com/rduivenvoorde/ so others can fork/use it?)
>> - I 'registre' the project to hub.qgis.org (thereby making it possible
>> for others to issue bugs).
>> http://hub.qgis.org/projects/qgis-user-plugins
> Theoretically you don't need to create a project on github - when
> registered on hub.qgis you should be able to get git repository
> directly there. However obviously something is wrong with the server
> settings, since the read-only URLs for repositories listed for various
> plugins are not working, e.g.
> $ git clone http://qgis.org/git/file-browser.git
> Cloning into file-browser...
> fatal: http://qgis.org/git/file-browser.git/info/refs not found: did
> you run git update-server-info on the server?
> Similarly the developer URL requires a password for 'gitosis' user and
> it is not clear what password to enter.
> @Pirmin / Alex - any idea what's going on?
Did you upload your pubkey?
http://hub.qgis.org/my/public_keys
Regards
Tim
>> - I upload the plugin to the plugin repositories:
>> http://plugins.qgis.org/plugins/ (for qgis >-= 2.0)
>> http://pyqgis.org/ (for qgis <2.0)
> plugins.qgis.org repository is nowadays mainly in testing mode, unless
> you would like to help with testing it is sufficient to upload the
> plugin to pyqgis.org. I foresee we will do some backwards incompatible
> changes regarding the plugins (e.g. metadata in a text file, PyQt api
> 2), then we may announce that repository is ready for 2.0 only
> plugins.
>> Do I miss something here?
>> Like: is there a central page do write some information about the plugin
>> (I normally did that on my own server, but are happy to do that
>> somewhere else (rst preferably).
> On the hub.qgis when registered a project you get also a wiki,
> documents, news and files section - probably everything you would need
> for a plugin.
>> Is there already a wikipage for this scenario? If not I will write this
>> down in a page.
> I am not aware of that.
> Martin
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
