[Qgis-developer] new plugin scenario
Alex Mandel
tech_dev at wildintellect.com
Sat Aug 27 21:11:13 EDT 2011
I believe for read-only access that does not require you to be a member
of the project we need to enable a gitweb service on the server or
something similar via apache - gitosis from what I know is for handling
authenticated actions on git repos over ssh.
I can explore this more is September.
Thanks,
Alex
On 08/27/2011 02:40 AM, Marco Bernasocchi wrote:
> Hi, the problem with the read only url exists since longer, I had a
> similar problem back in march publishing my masters thesis plugins.
> Pirmin said something about a needed server update, but I can't recall
> what was it and couldent find it in the archives.
> sorry
> Marco
> On 08/27/2011 11:20 AM, Martin Dobias wrote:
>> On Fri, Aug 26, 2011 at 11:59 PM, Tim Sutton<lists at linfiniti.com> wrote:
>>>> Theoretically you don't need to create a project on github - when
>>>> registered on hub.qgis you should be able to get git repository
>>>> directly there. However obviously something is wrong with the server
>>>> settings, since the read-only URLs for repositories listed for various
>>>> plugins are not working, e.g.
>>>> $ git clone http://qgis.org/git/file-browser.git
>>>> Cloning into file-browser...
>>>> fatal: http://qgis.org/git/file-browser.git/info/refs not found: did
>>>> you run git update-server-info on the server?
>>>> Similarly the developer URL requires a password for 'gitosis' user and
>>>> it is not clear what password to enter.
>>>> @Pirmin / Alex - any idea what's going on?
>>> Did you upload your pubkey?
>>> http://hub.qgis.org/my/public_keys
>> No I didn't. Now after adding my public key and trying e.g.
>> $ git clone gitosis at qgis.org:metaedit.git
>> I get correctly asked for my passphrase for the private key. But then
>> the cloning fails:
>> ERROR:gitosis.serve.main:Repository read access denied
>> fatal: The remote end hung up unexpectedly
>> Probably only people marked as project developers are able to read the
>> repository?
>> For the record, the read-only URL fails with this error message:
>> $ git clone http://qgis.org/git/metaedit.git
>> Cloning into metaedit...
>> fatal: http://qgis.org/git/metaedit.git/info/refs not found: did you
>> Martin
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
