[Qgis-developer] new plugin scenario
Marco Bernasocchi
marco at bernawebdesign.ch
Sat Aug 27 05:40:46 EDT 2011
Hi, the problem with the read only url exists since longer, I had a
similar problem back in march publishing my masters thesis plugins.
Pirmin said something about a needed server update, but I can't recall
what was it and couldent find it in the archives.
sorry
Marco
On 08/27/2011 11:20 AM, Martin Dobias wrote:
> On Fri, Aug 26, 2011 at 11:59 PM, Tim Sutton<lists at linfiniti.com> wrote:
>>> Theoretically you don't need to create a project on github - when
>>> registered on hub.qgis you should be able to get git repository
>>> directly there. However obviously something is wrong with the server
>>> settings, since the read-only URLs for repositories listed for various
>>> plugins are not working, e.g.
>>> $ git clone http://qgis.org/git/file-browser.git
>>> Cloning into file-browser...
>>> fatal: http://qgis.org/git/file-browser.git/info/refs not found: did
>>> you run git update-server-info on the server?
>>> Similarly the developer URL requires a password for 'gitosis' user and
>>> it is not clear what password to enter.
>>> @Pirmin / Alex - any idea what's going on?
>> Did you upload your pubkey?
>> http://hub.qgis.org/my/public_keys
> No I didn't. Now after adding my public key and trying e.g.
> $ git clone gitosis at qgis.org:metaedit.git
> I get correctly asked for my passphrase for the private key. But then
> the cloning fails:
> ERROR:gitosis.serve.main:Repository read access denied
> fatal: The remote end hung up unexpectedly
> Probably only people marked as project developers are able to read the
> repository?
> For the record, the read-only URL fails with this error message:
> $ git clone http://qgis.org/git/metaedit.git
> Cloning into metaedit...
> fatal: http://qgis.org/git/metaedit.git/info/refs not found: did you
> Martin
> Qgis-developer mailing list
