[Qgis-developer] Composer Window loses SIGNAL/SLOT connection?
Düster Horst
Horst.Duester at bd.so.ch
Wed Aug 31 05:37:59 EDT 2011
Hi
My aim is to add an additional toolBar with one button the all ComposerWindows I open. I created the following code to achieve that.
def __init__(self, iface):
self.composerWindow = {}
self.myPrintAction = {}
myApp = self.iface.mainWindow()
QObject.connect(myApp, SIGNAL("composerAdded(QgsComposerView*)"), self.initPrintEnvironment)
def initPrintEnvironment(self, myComposerView):
self.printMenue = PrintMenue(self.iface, myComposerView)
self.composerWindow[myComposerView] = myComposerView.composerWindow()
myToolBar = QToolBar()
self.myPrintAction[myComposerView] = QAction(QIcon(), "SO!GIS Print", self.composerWindow[myComposerView])
myToolBar.addAction(self.myPrintAction[myComposerView])
self.composerWindow[myComposerView].addToolBar(myToolBar)
QObject.connect(self.myPrintAction[myComposerView], SIGNAL("triggered()"), self.printMenue.run)
The code logic works fine when I open the first composer window. A new toolbaar with one button and the text SO!GIS Print is created. Click on this button starts the expected printMenue. The composer 1 window is still open. Now I open a second composer window. Everything works fine in this window. But now when I switch back to composer1 window. A click on the does nothing. I can open composer windows as much as I like. Only the last created composer window has a functioning button.
Im not shure weather it is as problem of my code or the problem is hidden deeper in the QGIS code.
Ill apprecciate an help or hint.
Regards
Horst
Dr. Horst Düster
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
