[Qgis-developer] [Solved] Composer Window loses SIGNAL/SLOT connection?
Horst Düster horst.duester at kappasys.ch
Wed Aug 31 06:25:59 EDT 2011
OK sometimes it is good to describe a problem and oft it will happen to
find out the solution by yourself. The solution is:
self.printMenue[myComposerView] = PrintMenue(self.iface, myComposerView)
self.printMenue has to be a dictionary as well. Now it works.
Regards
Horst
Am 31.08.2011 11:37, schrieb Düster Horst:
> Hi
> My aim is to add an additional toolBar with one button the all ComposerWindows I open. I created the following code to achieve that.
>    def __init__(self, iface):
>      self.composerWindow = {}
>      self.myPrintAction = {}
>      myApp = self.iface.mainWindow()
>      QObject.connect(myApp, SIGNAL("composerAdded(QgsComposerView*)"), self.initPrintEnvironment)
>    def initPrintEnvironment(self,  myComposerView):
>        self.printMenue = PrintMenue(self.iface,  myComposerView)
>        self.composerWindow[myComposerView] = myComposerView.composerWindow()
>        myToolBar = QToolBar()
>        self.myPrintAction[myComposerView] = QAction(QIcon(), "SO!GIS Print",  self.composerWindow[myComposerView])
>        myToolBar.addAction(self.myPrintAction[myComposerView])
>        self.composerWindow[myComposerView].addToolBar(myToolBar)
>        QObject.connect(self.myPrintAction[myComposerView], SIGNAL("triggered()"), self.printMenue.run)
> The code logic works fine when I open the first composer window. A new toolbaar with one button and the text SO!GIS Print is created. Click on this button starts the expected printMenue. The composer 1 window is still open. Now I open a second composer window. Everything works fine in this window. But now when I switch back to composer1 window. A click on the does nothing. I can open composer windows as much as I like. Only the last created composer window has a functioning button.
> Im not shure weather it is as problem of my code or the problem is hidden deeper in the QGIS code.
> Ill apprecciate an help or hint.
> Regards
> Horst
> Dr. Horst Düster
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> Qgis-developer mailing list
Dr. Horst Düster
Burchacker 6
CH-4556 Aeschi
Tel.: +41 (0) 62 961 03 74
Mobil: +41 (0) 76 408 51 06
eMail: horst.duester at kappasys.ch
skype: horstduester
Web: www.kappasys.ch
